AWack
Compiler error when using TouchGFX code
I´ve created a project with TouchGFX, which works fine.
When I try to compile the project in CubeIDE I get the error ModelListener.hpp:9: undefined reference to `vtable for ModelListener
What could be the reason?
Best regards,
Achim
Graduate II
Hello
Have you modified the modelListener.hpp ?
Here seems to be same error
message https://community.st.com/t5/stm32cubeide-mcus/touchgfx-uart-to-ui-without-rtos/td-p/58712
Br JTP
AWack
AWackAuthor
I´ve nothing changed in the lines where the error occurs (contructor / destructor). And compiling with TouchGFX is sucessful! Only compiling with STM32CubeIDE fails!
I´ve the same code in an older project and it was possible to compile.
Best regards,
Achim
