ADrub.1
Colors in CubeIDE on Linux
Hi! I have Linux Mint 22.2. How can I configure CubeIDE colors so that all windows have a white background? Various combinations of Windows->General->Appearance settings allow you to achieve a maximum white background for all windows except the one where you edit the code.
Version CubeIDE 2.2.0
AScha.3
AScha.3Best answer
did you try basic color setting, not dark (as i have) , but light ...?
afair this is from system default , somewhere (!) you can change this to custom color...but i dont remember now, was searching some time for this.
...like this:
Hello @ADrub.1
Thank you for posting!
Have you tried to switch the Colors and font theme as "Default"?
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
ADrub.1
ADrub.1Author
I tried it. Here are the default values.
AScha.3
AScha.3Best answer
...like this:
ADrub.1
ADrub.1Author
Most likely, this problem can only be solved by selecting a light background for applications in the Linux Mint settings.
