dkim.3
Code Generation do not work
Hi
I changed My GPIO name and clicked the Code generation.
But the pop-up window turned on and off in an instant, My code didn't change.
AND everytime I click the code generation button, I can see the phrase "isbadioc=false" in IOC file.
is it IOC file is not normal?
how can I fix this situation?
please give me some solution.
Thanks.
AScha.3
AScha.3Best answer
Just try : make new project, only character in name, and no spaces, generate code ... for test.
or
close Mx , close IDE.
Then start IDE, open ioc and generate code .... might work.
AScha.3
not much info, so just guessing:
maybe you give the pin a name (in Cube) , beginning with "not a character" symbol, like " - Vss " ->
That can totally confuse the CubeMx - never do it !  write always only characters in first place, like "Vss" .
(I did it one time - had to make new project with new ioc file . )
So try : make new project, only character in name, and no spaces (also in project name and all path names ! ).
dkim.3
dkim.3Author
Thank you for your reply.
But I used the name like you said.
Project name is also do like that.(I checked all path)
is there another reason??
AScha.3
AScha.3Best answer
or
