change live expression Update rate in IDE
The STMcube IDE1.18.0  updates live expression very fast. How can I reduce the update rate, if possible?
How to accurately read ADC value for sensor calibration in this case ?
Karl Yamashita
That's the whole idea of live expression. It updates live.
  1. Print the values to a UART peripheral.
  2. You can pause debugging to view the value
  3. Slow down you ADC conversion so live view is updated at a slower rate.
VidhiPaAuthor
Yes, of course I understand that. I use workarounds like UART, but older version of STMCube IDE has it updated slowly than this version, so I wanted to know if there is a way to modify this.
Andrew Neil
@VidhiPa wrote:
I use workarounds (sic) like UART, .
In this application, I wouldn't call a UART (or similar) a "workaround" - I'd say it's a more appropriate approach to the problem.
Hello @VidhiPa
In addition to the suggestion of @Karl Yamashita, you can also Set breakpoints at points of interest and inspect variables when halted.
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
Andrew Neil
That's a separate question!
For this, I'd use output to a UART (or similar) as @Karl Yamashita suggested.
