cannot import and build STSW-IOM001
I bought a NUCLEO-F401RE and the STEVAL-IOM001V1 evaluation board to experiment with the IO-Link protocol. I’m having trouble importing STSW-IOM001 into my project. According to the documentation, it’s supposed to be opened in SW4STM32, which is an older tool. I’ve followed all the instructions I could find for importing it into STM32CubeIDE, but nothing has worked. Do you have any suggestions?
KDJEM.1
KDJEM.1Best answer
Hello @MOTREN ,
To solve this issue, I suggest that you add this instruction under main.c:
__attribute__((weak)) void _close(void){}
__attribute__((weak)) void _lseek(void){}
__attribute__((weak)) void _read(void){}
__attribute__((weak)) void _write(void){}
Please let me know if the issue is solved or not?
Thank you.
Kaouthar
AScha.3
did you try the P-NUCLEO-IOM01M1 ?
MOTRENAuthor
I haven’t tried it, but it seems to run with the NUCLEO-F446RE board
AScha.3
And what about the ->
You tried to use it ?
KDJEM.1
Hello @MOTREN and welcome to the community;
Thank you for bringing this issue to our attention.
I reported internally.
Could you try using an older version of STM32CubeIDE such as 1.11.0 or 1.16.0?
Internal ticket number: 216360 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Hello @MOTREN ,
Thank you.
Kaouthar
KDJEM.1
Hello @MOTREN ;
Is your issue solved?
If yes, please click on Accept as Solution on the reply which solved your issue.
Thank you.
Kaouthar
