KFeng.2
Can't install package in Embedded Software Packages Manager (M1 Pro)
Environment:
  • STM32Cube IDE version 1.8.0/1.9.0
  • MacBook Pro 14" 2021 (Apple M1 Pro / macOS Monterey 12.3)
To reproduce:
  • Help > Manage Embedded Software Packages
  • Can't select any items to install
Florent V
Florent VBest answer
Hi @KFeng.2​ ,
Indeed it is a known bug on MacOS.
Waiting for a fix, there are 2 workarounds:
  • Download the pack manually and install it using "From Local..." button from "Embedded Software Packages Manager" window. Or
  • If the project has been created through CubeMX standalone, you can install the pack from CubeMX.
Regards,
Florent
Florent V
Hi @KFeng.2​ ,
Regards,
Florent
KFeng.2
KFeng.2Author
Tried the 2 workarounds, ok for MacOS.
Thank you.
mattias norlander
In discussion with Florent, the ST internal ticket reference is: 119647.
