DK.7
Can't install 'Devstyle' on STM32Cubeide V1.18.1!
My 'OS' is Debian12.
And as you can see from the question above, I'm having trouble installing the theme for CubeIDE v1.18.1
See attached screen.
AScha.3
I run MxLinux (up to date).
Seems there is a problem in access to "marketplace" in 1.18.1 ;
can you open marketplace and search/select ...anything ?
DK.7
DK.7Author
No, it takes a long time to load and eventually does not connect to the marketplace!
Same behavior in CubeIDE v1.15.1.
PS, I need to customize CubeIDE appearance and fonts, because by default it is not possible to work at all! Maybe someone knows how to configure CubeIDE manually without DevStyle?
AScha.3
...this is how my IDE is looking:
Using any new plugins from "market" can be dangerous - i had to delete and install IDE new,
after testing some plugins - changes could not be reversed !
So more save: use the settings, that are already here: menu -> window -> preferences
- first:
- then: many ...editor, debug etc.
- and the syntax colors you like:
- and what it shows in menu and tollbars :
/for every perspective ! / edit / debug / Mx
menu-> window -> perspective -> customize...
btw   - what i like :  mark occ. of sel. text
- and breakpoints better visible:
-> here : marked text "fresult" and a breakpoint
