Mohan1
Can i write polynomial equation in STM32cubeIDE
I am trying to estimate initial SOC of battery by using a polynomial equation obtained from discharged voltage data of battery. I successfully run this polynomial equation in MATLAB but don't know how to write in STM32cubeIDE.
The obtained polynomial equation is-
p1 = 9.722*10^(-24);
p2 = -1.565*10^(-19);
p3 = 9.908*10^(-16);
p4 = -3.139*10^(-12);
p5 = 5.22*10^(-9);
p6 =-4.318*10^(-6);
p7 = 0.00127;
p8 = 3.709;
x=4;
j = p1*(x.^7)+p2*(x.^6)+p3*(x.^5)+p4*(x.^4)+p5*(x.^3)+p6*(x.^2)+p7*(x)+p8
Here 'j' is polynomial equation and 'x' is initial voltage of battery.
Thanks.
January 2, 2020
Write it in C
p1 = 9.722e-24;
j = p1*pow(x,7) + p2*pow(x,6) ...
Mohan1
Mohan1Author
@Community member​ Thanks for your response sir.
RMcCa
Senior II
January 2, 2020
You could also declare 2 vectors (1 dimensional arrays) and use arm_dot_prod_f32() to do all the multiplying and adding.
Declare p[8] and initialize all 8 values and x[8]. Set x[0] = 1.0 and then use a for loop to calculate the other x[]s as they are simply the input value * the previous x[].​
Mohan1
Mohan1Author
@RMcCa​ Thanks for your reply sir.
