Muhammed Güler
Senior III
December 2, 2021
There is no ethernet in the STM32U series. STM has nothing to support either. If you plan to connect to the network with another device, the MQTT protocol becomes a software project where you can find a library.
I found examples made with ESP8266 but I didn't try
http://www.atakansarioglu.com/how-to-iot-mqtt-on-stm32-cortex-m-esp8266-wifi-temperature-freertos/
https://mehmettopuz.net/esp8266-ve-stm32-ile-mqtt-protokolu/.html
Guillaume K
Hi
On B-U585I-IOT02A board there's a WiFi chip that allows to connect to TCP-IP network.
There's an MQTT example with this board: Nx_MQTT_client. It uses AzureRTOS and Azure TCP-IP stack (NetXDuo).
Guillaume K
Note that the B-U585I-IOT02A has a ​STM32U585AIIxQ. There's no STM32 board that has a ​STM32U585QII3 as you request.
