IVent.1
Senior
Apr 12, 2024 2:09 PM UTC
C++ compile multiple definition
I have a C project, it compiles perfectly.
I changed the extension of main from main.c to main.cpp.
I use the function "Convert to C++", I did "Clean project"
but when I compile the project, I have a bulk of compiling error of this type:
C:/myproject/Debug/../Src/filex.c:62: multiple definition of `Function1'; ./Src/app_filex.o:C:/myproject/Debug/../Src/filex.c:62: first defined here
and this for every functions, I suppose.
Any suggestion?thank you
IVent.1
IVent.1Best answer
Senior
Apr 17, 2024 8:59 AM UTC
At the end, I did the project from the beginning, starting directly as a C++ project, adding files by files starting from main, because no way to find the problem in the original project. Thank you.
Andrew Neil
Apr 12, 2024 2:13 PM UTC
So take a look at those errors: they tell you where each of the multiple definitions is - look at those definitions.
IVent.1
IVent.1Author
Senior
Apr 12, 2024 4:14 PM UTC
I don't have more than one definition.
Andrew Neil
Apr 12, 2024 4:38 PM UTC
The errors say you do!
Post the full errors, and the source code to which they relate.
In both cases, use this button to post the text:
Copy & paste the errors from the 'Console' window.
