JDydy.1
Build error
Hi, i have a STM32Cube project, that builds in stm32cubeide, however when porting it to VSCode extension and trying to build with cmake i get linker error saying: ../arm-none-eabi/lib/crt0.o: in function `_mainCRTStartup': undefined reference to 'main'. Does anyone have any ideas how to solve that?
March 24, 2023
If you have main() function in a C++ file, perhaps use extern "C" so it exports
JDydy.1
JDydy.1Author
That's not the case here, since i am using C
Nawres GHARBI
Hi @Jakub Dydyński​
could you attach your output log and project
JDydy.1
JDydy.1Author
I attached output. Regarding project it is an example from you site: V53L0A sensor with XNUCLE53L0A. I have ported the project to stm32 cubemx since the project on your site was for SW4STM32 which is old ide i suppose.
Piranha
Principal III
March 29, 2023
> _mainCRTStartup
https://learn.microsoft.com/en-us/cpp/build/reference/entry-entry-point-symbol
That function is a C runtime entry-point for Windows console applications. Probably you are building a Windows application instead of ARM firmware.
