Build and debug code on STMCUBE IDE using IAR tool chain as compiler
Hi ,
I have IAR license and I want to build the code on CubeIDE but use the IAR compiler is there any simple method for eg IAR plugin or anything else
Andrew Neil
If you've paid for an IAR licence, why not just use the IAR IDE?
Anyhow, if you go to Window > Preferences, there is 'Toolchain Manager':
curiocityAuthor
Hi andrew ,
Thanks for your reply
I believe the Tool Manager can't be used with the IAR compiler because it is designed for GNU-style compilers that have standard command-line interfaces. Could you please confirm if this understanding is correct?
Andrew Neil
I don't know.
If I had to use the IAR compiler, I would just use it from IAR's IDE.
Pavel A.
IAR toolchain can be used with VS Code. Their support will be happy to point you to the documentation.
https://www.iar.com/embedded-development-tools/iar-visual-studio-code-extension
