Build Analyzer with CMake toolchain
Can anyone confirm that the Build Analyzer in the CubeIDE works when using the CMake toolchain? For compatibility reasons I'm currently stuck at IDE version 1.16.1. I created a fresh CMake Project for a Nucleo board (U545). It creates the elf and map files just fine but the Build Analyzer stays empty. (Yes, I tried the refresh button...)
If someone could confirm that a newer IDE version does the job, I'll try to convince the project team. Or what I could do to make it work in 16.1. Thanks!
TDKBest answer
If, after building, you right click the project and refresh, then refresh the build analyzer, does it work? It might be looking for the elf at a specific location (e.g. Debug/project.elf), but I'm not sure if that's configurable. Seems like its behavior was hard coded for typical projects.
TDKBest answer
strygaAuthor
It seems that I missed the refresh on the project! Thanks a lot.
