BVauc.1
May 5, 2020 11:33 AM UTC
bug report: STM32F302CBT6 failed to compile
Hi, This particular MCU is not fully populate in project generator, the result when trying to create a project is incomplete project that can't compile. I worked-around by selecting a different MCU, but as migrating between MCU is not supported, I am facing a wall, and I don't know how to workaround.
Thanks for you attention! Bernard
May 5, 2020 1:09 PM UTC
Hello @BVauc.1​ ,
Please share your ioc file to check your project, maybe it is not set up properly.
What do you mean migrating between MCU is not supported ? Did you search and select "List Pinout Compatible MCUs" from the Pinout menu ?
Best Regards,
Imen
BVauc.1
BVauc.1Author
May 5, 2020 4:49 PM UTC
Hello, thanks for checking, it was an automatic update just now that seems to solve the issue, if you are at this initiative, thank you, it works now.
BVauc.1
BVauc.1Author
May 5, 2020 4:58 PM UTC
What I mean by migrating: once a project is created in CubeIDE, there is no possible to replace the MCU type by another type. Is it correct?
