B-U585-IOT02A BSP example issues
Hello forum
I have just purchased the B-U585-IOT02A and would like to start and interact with all of the sensors on in,
for it, I tried the IDE example of the BSP in general, but it didn't even compile. even after trying to manually use the driver nothing's working
it give the "No source available for  _swistat() ..."
can someone help?
Thanks in advance.
I had a similar compilation issue with B-U585-IOT02A.
The problem lies in the workspace path.
The attached tutorial will help you out.
