Mike xx
May 16, 2024 3:29 PM UTC
Assign a variable to the c-file line number.
I have a FreeRTOS queue with many calls from various tasks.
I would like to assign elements of a variable that is passed into the queue with the file name and line number of the task that is placing the variable on the queue.
I have a corruption issue that might be a stack or perhaps an array that is being sent to the queue that is not copied but sent as a reference?
At the moment I have started to hand code the line numbers, but it's not ideal.
Can anyone help?
    Andrew Neil
    Andrew NeilBest answer
    May 16, 2024 3:33 PM UTC
    __FILE__ and __LINE__
    https://gcc.gnu.org/onlinedocs/cpp/Standard-Predefined-Macros.html
    EDIT:
    GCC also provides __FILE_NAME__ to give just the name, without path:
    https://gcc.gnu.org/onlinedocs/cpp/Common-Predefined-Macros.html
    Andrew Neil
    EDIT:
    Mike xx
    Mike xxAuthor
    May 16, 2024 3:49 PM UTC
    Many thanks for the quick reply.
    My previous google searched had failed me. I hadn't search with gnu or gcc.
    I thought they must exist as they do for the IAR compiler.
    Andrew Neil
    May 16, 2024 4:01 PM UTC
    You're welcome.
    Yes, they are part of the C Standard - apart from __FILE_NAME__
    If that's answered the question, please mark the solution.
