After STM32CubeMX generated the code, the file I created earlier disappeared
         After I use STM32CUBEIDE's built-in STM32CUBEMX to generate code, the source files and header files under the folder I created myself disappeared, how can this be solved?
        Before I use STM32CUBEIDE's built-in STM32CUBEMX to generate code:
      After I use STM32CUBEIDE's built-in STM32CUBEMX to generate code,all the files I created disappeared.
     The compilation path of the file I created has already been saved, and I also checked the keep user code when re-generating option
Hello @sky_lin
Could you attach your project to investigate the issue?
KR,
Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
sky_linAuthor
Yeah , I have uploaded my project.
Bob S
Also see this (in the "too late to help this time but will help NEXT time): https://community.st.com/t5/stm32cubeide-mcus/my-usb-cdc-if-file-was-deleted-by-code-automatically-without/m-p/814264#M36899
Even the best written tools can fall prey to OS/hardware issues beyond their control and corrupt your data.
