chriskuku
Senior II
July 24, 2023
Adding a file (Inc)
Somehow I'm blinded at the moment. How do I simply add a file from the filesystem into the project ?
I created a header file "times.h", put it into ~/STM32CubeIDE/workspace_1.4.0/project/Core/Inc. Now it sits there. Opening the tree view, I don't see it. Clicking "New" I don't see an option to import a file. Only create new ones.
Ah, now, I tried "Refresh" and it's there. Soemhow counterintuitive. But probably this is owed to Eclipse?
    Ghofrane GSOURI
    Ghofrane GSOURIBest answer
    Hello @chriskuku
    First let me thank you for posting.
    In order to import a file you need to follow those steps:
    - Click on File -->Import
    - Under General , select File System  then next
    - Choose the directory where the file exist and then select the file and finally click on finish
    Thx
    Ghofrane
    Ghofrane GSOURI
    Hello @chriskuku
    Thx
    Ghofrane
    Pavel A.
    July 24, 2023
    Yes, Eclipse. Live and learn ))
    chriskuku
    chriskukuAuthor
    Senior II
    July 24, 2023
    Thanks for the detailed tour. Yes, import from file system is the solution. I forgot.
