RPriy
Add CppuTest Library and Includes in a New Build configuration of a Project
0693W000001rYivQAE.pngIn this image, I have created a new build configuration of Test inside the project & trying to add external library (.a) of CppUTest but not getting add library and library path option. Could you guide me on how to add libraries to any new build configuration created within a project ?
Awaiting your early response.
Ritu
Cartu38 OpenDev
Graduate II
June 26, 2020
Here is one example extracted from STM32Cube AI pack setup. I guess you have to apply same.0690X00000BvtszQAB.png
RPriy
RPriyAuthor
This option is also not coming for New Build Configuration.
Cartu38 OpenDev
Graduate II
June 28, 2020
Here just a context issue ... have try asking for properties on project folder instead your compilation folder ... you will see much more options.
RPriy
RPriyAuthor
I intent to include unit test for my firmware for which I have added New build configuration named "Test" (you can see in above pic). I just need to link library of CppUTest to this build configuration so that it doesn't affect the build of the firmware. If you have any other suggestion/way to do this, please help with it.
Cartu38 OpenDev
Graduate II
June 30, 2020
Not sure to get your issue here then ? I've provided you way to get access to proper option and their setup so ???
