Would like to be able to use Build Analyzer.
I hope to use the same Build Analyzer in VSCode as in the IDE, which allows developers to more clearly see the use of flash and memory. I have tried to use GPT to write a plugin, but the effect is not good, and I don't understand the JS language well, so it is difficult to develop it by myself.
My mother tongue is not English, please forgive me if it is not easy to understand.
mattias norlander
Update: Build analyzer will come during 2025 Q1/Q2. It works internally already.
But due to architectural changes and legal constraints we cannot deploy it yet.
Pavel A.
If you want to convince (or sponsor) someone to make this tool for VS Code - you're welcome! A good idea.
(but most likely it already exists, because it is based on well known format of linker .map file, maybe .ld files too).
HolliesAuthor
Yes, it parses the map file format, but I haven't found anything like it in the extension marketplace, nor any relevant content through search engines. Perhaps reverse-engineering the official Java plugin could be an option, but I haven't learned Java yet either.
Southbranch
Senior
Hi!
I also lack this functionality a lot in VS Code.
Any news regarding recommended extensions etc?
HolliesAuthor
I don't have any new information.
Perhaps there are fewer people using VS Code for this specific purpose.
ATwice291
Explorer
Hi! I started using VSCode as an alternative to CubeIDE and came across this topic while looking for a build analyzer for VSCode. I’m young and inexperienced, so the idea of creating my own plugin for VSCode doesn’t scare me yet. Were you able to achieve much? Maybe I don’t need to start from scratch?
mattias norlander
HolliesAuthor
Thank you so much for your efforts.
ATwice291
Explorer
mattias norlander
Maybe some more context...
2025-05-07, we deployed version 3.x our ST VS Code extension. There is a sticky post about this in this forum.
As part of this pre-release deployment, we provide a new build analyzer. It looks like this:
This pre-release is available here:
At the marketplace you can read the readme.md and the changelog.md to understand a bit more. More info coming step-by-step in a continuous delivery spirit.
