VSCode: RtosProxy error with big thread stack on ThreadX
- 18 replies
- 1255 views
During a debugging session, when `tx_thread_create` is called with a "big" stack size (1024*10 for example) and the "serverRtos" is enabled, the debugger is disconnected with an error: "Remote communication error. Target disconnected: No error."
Here the debug console logs (full log attached):
Spoiler
To client: {"seq":0,"type":"event","event":"output","body":{"category":"proxy","output":"RTOS proxy: Lost connection to GDB Server\r\n"}}
To client: {"seq":0,"type":"event","event":"output","body":{"category":"stdout","output":"{\"label\":\"\",\"value\":[{\"label\":\"Driver\",\"value\":\"ThreadX\"},{\"label\":\"Kernel state\",\"value\":\"Not started\"}]}\n"}}
{"label":"","value":[{"label":"Driver","value":"ThreadX"},{"label":"Kernel state","value":"Not started"}]}
GDB result: 36 done
To client: {"seq":0,"type":"response","request_seq":25,"command":"cdt-gdb-tests/executeCommand","success":true,"body":{"status":"Ok","result":{},"console":["monitor rtos -m state\n","{\"label\":\"\",\"value\":[{\"label\":\"Driver\",\"value\":\"ThreadX\"},{\"label\":\"Kernel state\",\"value\":\"Not started\"}]}\n"]}}
To client: {"seq":0,"type":"event","event":"output","body":{"category":"proxy","output":"RTOS proxy: Proxy stopped.\r\n"}}
GDB notify async: thread-exited,id="1",group-id="i1"
GDB notify async: thread-group-exited,id="i1"
GDB result: 37 error,msg="Remote communication error. Target disconnected: No error."
GDB result: 36 done
And the very basic code used:
/* USER CODE BEGIN Header */
* @file app_threadx.c
* @author MCD Application Team
* @brief ThreadX applicative file
* @attention
* Copyright (c) 2025 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "app_threadx.h"
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
TX_THREAD tx_app_thread;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
VOID th_main(ULONG thread_input)
while (1)
tx_thread_sleep(1);
TX_THREAD p_thMain;
#define MAIN_THREAD_STACK_SIZE (1024*10)
CHAR thMain_stack[MAIN_THREAD_STACK_SIZE];
/* USER CODE END PFP */
* @brief Application ThreadX Initialization.
* memory_ptr: memory pointer
* @retval int
UINT App_ThreadX_Init(VOID *memory_ptr)
UINT ret = TX_SUCCESS;
TX_BYTE_POOL *byte_pool = (TX_BYTE_POOL*)memory_ptr;
/* USER CODE BEGIN App_ThreadX_MEM_POOL */
/* USER CODE END App_ThreadX_MEM_POOL */
CHAR *pointer;
/* Allocate the stack for tx app thread */
if (tx_byte_allocate(byte_pool, (VOID**) &pointer,
TX_APP_STACK_SIZE, TX_NO_WAIT) != TX_SUCCESS)
return TX_POOL_ERROR;
/* Create tx app thread. */
if (tx_thread_create(&tx_app_thread, "tx app thread", tx_app_thread_entry, 0, pointer,
TX_APP_STACK_SIZE, TX_APP_THREAD_PRIO, TX_APP_THREAD_PREEMPTION_THRESHOLD,
TX_APP_THREAD_TIME_SLICE, TX_APP_THREAD_AUTO_START) != TX_SUCCESS)
return TX_THREAD_ERROR;
/* USER CODE BEGIN App_ThreadX_Init */
tx_thread_create(&p_thMain, "Main Thread", th_main, 0, thMain_stack,
MAIN_THREAD_STACK_SIZE, TX_APP_THREAD_PRIO, TX_APP_THREAD_PREEMPTION_THRESHOLD,
TX_APP_THREAD_TIME_SLICE, TX_APP_THREAD_AUTO_START);
/* USER CODE END App_ThreadX_Init */
return ret;
* @brief Function implementing the tx_app_thread_entry thread.
* thread_input: Hardcoded to 0.
* @retval None
void tx_app_thread_entry(ULONG thread_input)
/* USER CODE BEGIN tx_app_thread_entry */
while (1)
tx_thread_sleep(100);
/* USER CODE END tx_app_thread_entry */
* @brief Function that implements the kernel's initialization.
* None
* @retval None
void MX_ThreadX_Init(void)
/* USER CODE BEGIN Before_Kernel_Start */
/* USER CODE END Before_Kernel_Start */
tx_kernel_enter();
/* USER CODE BEGIN Kernel_Start_Error */
/* USER CODE END Kernel_Start_Error */
* @brief App_ThreadX_LowPower_Timer_Setup
* count : TX timer count
* @retval None
void App_ThreadX_LowPower_Timer_Setup(ULONG count)
/* USER CODE BEGIN App_ThreadX_LowPower_Timer_Setup */
/* USER CODE END App_ThreadX_LowPower_Timer_Setup */
* @brief App_ThreadX_LowPower_Enter
* None
* @retval None
void App_ThreadX_LowPower_Enter(void)
/* USER CODE BEGIN App_ThreadX_LowPower_Enter */
/* USER CODE END App_ThreadX_LowPower_Enter */
* @brief App_ThreadX_LowPower_Exit
* None
* @retval None
void App_ThreadX_LowPower_Exit(void)
/* USER CODE BEGIN App_ThreadX_LowPower_Exit */
/* USER CODE END App_ThreadX_LowPower_Exit */
* @brief App_ThreadX_LowPower_Timer_Adjust
* None
* @retval Amount of time (in ticks)
ULONG App_ThreadX_LowPower_Timer_Adjust(void)
/* USER CODE BEGIN App_ThreadX_LowPower_Timer_Adjust */
return 0;
/* USER CODE END App_ThreadX_LowPower_Timer_Adjust */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
