Nawres GHARBI
Jan 5, 2024 9:17 AM UTC
VSCode How to install VCPKG on VSCode with Zscaler/Proxy
Issue:  The VSCode don't have the ability to route the extension network requests to the proxy (only VSCode application network is routed to the proxy)
I -  the clean way (applies to network with Zscaler installed)
  1. ask for a Zscaler power user profile from your IT support
  2. request an access to those links if blocked by your firewall/proxy
    1. https://www.7-zip.org
    2.  https://github.com
    3.  https://aka.ms
    4.  https://artifacts.keil.arm.com
    5.  https://mirror.msys2.org
    6.  https://repo.msys2.org
II - The Workaround
  1. Set VSCode Proxy http://user:pass@domain:port
  2. Set Git Proxy correctly
  3. Set IE proxy correctly
  4. Set VCPKG_ROOT env variable
  5. Install STM32 Extension
  6. VCPKG install
    1. Launch VSCode (re-launch after previous configurations)
    2. Open VSCode Terminal (view -> terminal)
    3. Cd c:\
    4. git clone https://github.com/microsoft/vcpkg
    5. .\vcpkg\bootstrap-vcpkg.bat (if you got an error check your git proxy)
    6. In the vcpkg folder create a “downloads” folder
    7. Download these packages and put them under vcpkg\downloads folder:
      1. https://www.7-zip.org/a/7z2301-extra.7z
      2. https://github.com/madler/zlib/archive/v1.3.tar.gz
    8. Type "vcpkg install 7zip" in the terminal
    9. Type "vcpkg integrate install" in the terminal
  7. VCPKG activation
    1. Open STM32 Extension
    2. Create a project
    3. Import the created project
    4. In the vcpkg/download folder create a registry folder
    5. Download this zip and extract it in registry folder
      https://artifacts.keil.arm.com/vcpkg-ce-registry/registry.zip
    6. Open vcpkg-configuration.json file
    7. Replace the content by this text and save
    8. Open C:\vcpkg\vcpkg-configuration.json and do this modification
    9. Copy "c:\vcpkg" content to "C:\Users\xxxxx\AppData\Roaming\Code\User\globalStorage\ms-vscode.vscode-embedded-tools\vcpkg\root" and override files
    10. Close and restart VSCode
