Jul 14, 2026 09:58 UTC
Stm32CubeIDE for Visual Studio Code - The project conversion tool doesn't copy over assembly files, .s files.
As the title describes, the conversion tool to convert Stm32CubeIDE projects over to Visual Studio Code seems to work. Apart from the fact that, at least in my case, it failed to copy over the assembly files, .s files, in the project.
Which led to build errors, specifically thumb mode errors.
Just posting this here so that it may help others. Not quite sure how best else to let others know.
Julien D
Julien DBest answer
Jul 28, 2026 14:25 UTC
Thanks ​@ad101, for your screenshot. It helped a lot in understanding the root cause.
This is only a matter of file extension: the exporter considers only .s files as assembler sources, not .S files.
You can confirm this on your side by simply renaming the assembly sources to *.s.
I created an internal ticket to address this bug. Thanks again for helping improve the robustness of our extensions.
ad101Author
Jul 29, 2026 15:19 UTC
Ah ha, great to hear you found the issue. Thanks for you help, glad I could help as well  :)
