STM32cube registers tree cannot close when debug complete
Each time the debug function is used, there will be one more item in the STM32cube registers tree of the debug interface
Cartu38 OpenDev
Cartu38 OpenDevBest answer
Graduate II
Known behavior ...
https://marketplace.visualstudio.com/items?itemName=stmicroelectronics.stm32cube-ide-registers is claiming to inherit from https://marketplace.visualstudio.com/items?itemName=eclipse-cdt.peripheral-inspector and this one behaves the same.
Very same applies to https://marketplace.visualstudio.com/items?itemName=mcu-debug.peripheral-viewer
Sounds kind of must have if running multiple debug sessions at same time (multi core devices as example) but for basic device a bit annoying yes.
Workaround I've found is to reload or restart VSCode
Hello @sukiElaina,
Could you share your debug configuration in launch.json?
            "type": "stlinkgdbtarget",
            "request": "launch",
            "name": "STM32Cube: STM32 Launch ST-Link GDB Server",
            "origin": "snippet",
            "cwd": "${workspaceFolder}",
            "runEntry": "main",
            "imagesAndSymbols": [
                    "imageFileName": "${command:st-stm32-ide-debug-launch.get-projects-binary-from-context1}"
            "preBuild": "${command:st-stm32-ide-debug-launch.build}"
Cartu38 OpenDev
Graduate II
Known behavior ...
