STM Studio showing error
While uploading application or FSBL ELF File it is showing a dwarf error!! I tried downloading new version of STM Studio but similar problem occurred in that too; Could you suggest other alternate method so that I can fetch data.
Nawres GHARBI
HI @nishanth
Check Toolchain and File Compatibility, Ensure your ELF file is built with a compatible toolchain version matching your debugger version. Mismatches can cause DWARF errors.
you are maybe pointing on another compiler than the the embedded one with the extension, check your settings.
these are my first thoughts, we may need some more info to help you with this issue, logs, versions, elf files if not confidential ...
