Dec 29, 2025 13:06 UTC
Setup STM32Cube project not possible?
I'm trying to start using STM32CubeIDE for VS Code 3.7.0
I have tried to follow the instructions to set up an example project via STM32CubeMX and those to setup an empty project.
In both cases I end up with an apparently unconfigurable project, seeing just this:
Clicking on "Configure" does not result in a change.
Just trying to build the project anyway results in CMake telling me that it cannot find the C Compiler.
Any hint welcome.
Many thanks,
Titus
elbe_25Best answer
Apr 25, 2026 08:49 UTC
Thanks a lot for all the replies.
After some more retries, I gave up on this.
I have my own long established and well working C++ setup, also for but not only for STM32 MCUs.
I don't want and I don't need the bundle management, build system, and all the other stuff that gets pulled in by the STM32Cube extensions.
All I really need is up-to-date debugging support for current STM32 MCUs.
Hence, I opened a feature request to split debugging support VSCode extensions from Core + Build .
KnarfB
Dec 29, 2025 22:46 UTC
The above window won't go away after configuration. That seems to be expected (but maybe unintuitive) behaviour.
But, if CMake cannot find the compiler sounds like another, unrelated issue. You may open the command palette (
Ctrl+Shift+P) and enter 'bundle'. Various commands dealing with bundles will appear. The compilers are part of gnu-tools-for-stm32 and should be installed.
hth
KnarfB
Nawres GHARBI
Dec 31, 2025 08:45 UTC
hi @elbe_25  could you share the log after clicking the configure button please
elbe_25Author
Jan 1, 2026 11:35 UTC
Thx for the replies.
Hi @Nawres GHARBI
I already attached the log file from AppData\Roaming\stm32cube\logs\vsx to the OP. Otherwise please tell which log.
Maybe that gives an additional hint:
Sometimes when opening the project configuration page, I see an additional dialog item shortly flashing on the screen. but it's too short to recognize what might be there.
All other screen shots of the project config page that I came across during my search include more than just the dialog items in my above screen shot.
@KnarfB Quite a few bundles are installed.
I can also manually execute the compiler inside of the bundles directory from a shell. Since this directory is not in the PATH, I have to prepend its installation directory.
It's obvious that the generated CMake Toolchain file does not specifiy the full path to the compiler.
Question is: How is this is supposed to work with the STM32Cube IDE for VSX:
Is the cube-cmake aware of the path to the toolchain? Would the path go into another config file? Am I supposed to fiddle around with the paths manually in the toolchain file?
brucegong
Jan 2, 2026 00:12 UTC
You were misled by ST's early documentation. With the toolchain and development method you described, the correct approach is: 1. Use STM32CubeMX to generate your project framework, preferably selecting CMake + ST ARM Clang as the output toolchain; 2. Open and compile the generated project with VSCode.
The entire process does not require the step you mentioned. Also, probably few people still use the method you described for working with ST microcontrollers. When STM32CubeMX generates the framework, it has already configured most of the toolchain.
elbe_25Author
Jan 2, 2026 09:00 UTC
I'm following the "User guide":
Both creating an example project with STM32CubeMX and creating an empty project give the results described above.
If there is another documentation *applicable for version 3.7.0* to read, please post a link.
Thx
Jan 2, 2026 06:35 UTC
Hello ,
Suggest Beginner Guide documentation stm32cube ide with vs code how to setup and create project.
GS
Nawres GHARBI
Jan 6, 2026 07:48 UTC
Seems it is trying to download the 1.1.1 dfp pack version but something is going wrong, could you please check which pack version is installed and try to manually update it
elbe_25Author
Jan 9, 2026 07:34 UTC
How and where should I install STMicroelectronics.stm32n6xx_dfp.1.1.1?
Attached is the log file of today.
Cartu38 OpenDev
Graduate II
Jan 9, 2026 16:27 UTC
@elbe_25
Here possibly Thanks command palette
Or VSCode integrated terminal:
Julien D
Jan 12, 2026 09:19 UTC
Hi @elbe_25,
Do you already see any .settings/bundles.store.json file in your project? If so what is defined inside?
elbe_25AuthorBest answer
