Visitor
Run without debugging on VSCode
Help, how do I perform flashing only without debugging when using STM32CubeIDE for VS Code? I have reviewed previous posts, but the most recent Q&A on this issue seems to be from a year ago, and the methods mentioned there appear to be outdated. I am not sure how to achieve this functionality in the latest version.
jiangfan
You may try:
Use the extension’s flash/program command or a CubeProgrammer-based task, not the debug launch. Flash-only is typically performed through a dedicated program/download action, separate from debugging.
NOTE: reviewed answer with help from AI
​@shishun shi
How to deploy image without debugging? | Community is still valid.
