Explorer
Jul 23, 2026 11:57 UTC
How to hot-plug debugger to STM32 using VS Code
Hi, how do I configure launch.json to use hot plug?
Florent V
Florent VBest answer
Jul 25, 2026 07:36 UTC
Hi ​@pr.tsmaz,
Here the debug configuration to use hot plug:
"type": "stlinkgdbtarget",
"request": "launch",
"name": "STM32Cube: Launch ST-Link GDB Server",
"origin": "snippet",
"cwd": "${workspaceFolder}",
"preBuild": "${command:st-stm32-ide-debug-launch.build}",
"serverReset": "None",
"imagesAndSymbols": [
"symbolFileName": "${command:st-stm32-ide-debug-launch.get-projects-binary-from-context1}"
The serverReset attribute is set to None (to avoid reset at startup)
Define only symbolFileName in the imagesAndSymbols to load only the symbols
The runEntry attribute is not necessary is the hot plug case
KR,
/Flo
Florent V
Hi ​@pr.tsmaz,
KR,
/Flo
