How to build STM32H745 code using VS Code
Hi every one,
I want to program STM32H745 nucleo-144 using VS Code, after i generate the code using Cube MX with Toolchain "make file". But when i try to build the code this happen "Something went wrong during the build process: 1".
Can any one help me.
Thanks.
    vincent_grenetBest answer
    @Elite
    Takes care supported integration nowadays is about CMake not Make. CMakelists.txt are expected not Makefile.
    Makefile is possible such said but for now you have to rely on your own supported by some VSCode marketplace goods.
    Issamos
    Hello @Elite
    I suggest you to have a look at thisYouTube quick tutorial  to program your STM32 Using the VS code extension.
    Best Regards.
    II
    EliteAuthor
    Thanks dear
    @Elite
    EliteAuthor
    Thanks for reply,
    My mistake will solved if i used CMake instead of Makefile???
    thanks a lot
    Cartu38 OpenDev
    Graduate II
    @Elite board flashing is done at debug session launch time. Have a try !
