How should I use VS Code to develop a project based on the Standard Peripheral Library or the LL library?
Is there any way to automatically build the toolchain, even though the standard library is no longer recommended?
Nawres GHARBI
Nawres GHARBIBest answer
Hi @zhuxiaodics6
the only way to do it is to generate an empty project from the extension and do the needed modifications to add and build your lib
Nawres GHARBI
Hi @zhuxiaodics6
Thank you, I am learning how to write a Makefile to build a project
Cartu38 OpenDev
Graduate II
@zhuxiaodics6
CMake is the elected technology for now ... so I guess you're shooting for CMakelists.txt rather than Makefile ...
