Senior
How do I import existing CubeIDE project into VS Code (which uses CMake)?
I have a CubeIDE project and I want to continue development using VS Code.
How do you convert an existing project to CMake so I can use it in VS Code?
In CubeMX I opened the .IOC file to try to change the project settings to CMake but the Toolchain drop down menu is greyed out so I cannot change it. How do I change it to CMake specifically to be used with VS Code?
Thank you
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @Ricko
First let me thank you for posting.
Let's try this workaround :
After opening your IOC using STM32CubeMX , go to File --> Save project as --> select where to save the new IOC and change the name of the IOC then click save.
After doing this , try to change the toolchain to Cmake.
I 'will be waiting for your feedback.
THX
Ghofrane
Ghofrane GSOURI
Hello @Ricko
THX
Ghofrane
RickoAuthor
Senior
Thank you @Ghofrane GSOURI
it looks like it I can do that from standalone STM32CubeMX but not from the CubeMX inside CubeIDE's CubeMX Extension/Plugin. Inside the CubeIDE's CubeMX-plugin it shows greyed out as you can see from the attached screenshot.
It does that for all projects, so it is a CubeIDE bug I assume?
Where do you report bugs?
Thank you
Ghofrane GSOURI
Hello @Ricko
It's not a bug .
the CubeMX plugin within CubeIDE is meant to generate projects for STM32CubeIDE only.
THX
Ghofrane
