Choosing a specific device in JTAG chain
I can't seem to find the launch configuration setting to specify a device in the JTAG chain by its position and IRpre length. I'm using a J-link programmer and I can usually do this from the command line by passing the -jtagconf x,y argument to the J-link executable. However, the debug console in VScode shows that the debug launch config called the Segger J-link GDB server without this argument. I can't seem to find how to make the debug config to append this to the J-link server call
Is this supported by the STM32Cube extension?
Florent V
Florent VBest answer
Hi Visques,
The attribute serverJtagCfg will be available in the next delivery (planned for the end of November).
In the meantime, you can use the generic debug configuration to pass the -jtagconf argument in the serverParameters attribute.
Ex:
 "type": "stgdbtarget",
 "request": "launch",
 "name": "STM32Cube: STM32 Launch Generic GDB Server",
 "origin": "snippet",
 "cwd": "${workspaceFolder}",
 "preBuild": "${command:st-stm32-ide-debug-launch.build}",
 "program": "${command:st-stm32-ide-debug-launch.get-projects-binary-from-context1}",
 "gdb": "${command:st-stm32-ide-debug-launch.get-gdb-executable}",
 "serverExe": "JLinkGDBServerCL",
 "serverParameters": ["-s", "-if", "jtag", "-device", "STM32H723ZG", "-speed", "4000", "-endian", "little", "-novd", "-jtagconf", "9,2"],
 "serverHost": "localhost",
 "serverPort": "2331",
 "serverCwd": "<Path to your JLink installation>",
 "runEntry": "main",
 "imagesAndSymbols": [
 "imageFileName": "${command:st-stm32-ide-debug-launch.get-projects-binary-from-context1}",
 "imageOffset": "",
 "symbolFileName": "${command:st-stm32-ide-debug-launch.get-projects-binary-from-context1}",
 "symbolOffset": ""
 "verbose": true
(Note: Update the serverCwd attribute with your path)
Best Regards,
Flo
Florent V
Hi Visques,
Ex:
 "runEntry": "main",
 "imageOffset": "",
 "symbolOffset": ""
 "verbose": true
Best Regards,
Flo
VisquesAuthor
Thanks for your quick reply. I'll wait until the next update then
Florent V
Hi @Visques ,
Thanks to the latest 3.7.0 release, the attribute for JTAG configuration is now available.
"serverJtagCfg": "<IRPre>,<DRPre>",
With the tooltip:
Regards,
Flo
VisquesAuthor
Thanks so much!
Btw: Not sure if the information box should say TDO instead of TDI? Usually IRPre and DRPre are counted from TDO
VisquesAuthor
One more thing: How can I attach to a running STM32 target by using its specific JTAG address? If I select "attach" in "request" the "serverJtagCfg" option becomes invalid.
