Jan 31, 2025 9:44 AM UTC
C++ setup in VS code for STM32
Hello, Can someone advise me for a "blueprint" how to set up C++ in VS Code for stm32 mcu, I've changed Cmakelists.txt to be able to compile C++ and I am not getting an error at Cmakelists.txt, but I am still getting errors from undefined macros. I sense that it is related to IntelliSense and I've set all include paths in properties.json and stil it doesn't recognize some macros from different libraries. I just wanted to ask you if you know certain procedure for any type of project involving setting up C++ for STM32 in VS code.
Thanks in advance
Andrew Neil
Jan 31, 2025 4:30 PM UTC
What errors, exactly?
Should be easy to distinguish actual compiler errors from just "IntelliSense" issues?
NymerisVAuthor
Feb 1, 2025 2:25 PM UTC
Hi, yes exactly, I figured it out, those were errors from missing libraries. I thought that CubeMX has generated them. From Intellisense.
And the rest of errors was that I had to incorporate also the ST-Link server file location in properties.json and also location of gcc, but the gcc from CubeCLT location. And also the gcc location to Cmakelists.txt-s,
Many thanks,
NymerisVAuthor
Feb 1, 2025 2:26 PM UTC
I mean  the errors were from intellisense, it couldn't locate them.
