Add new C file to my STM32 project in VS Code
If I add a new .c file to my project in core/src it does not get recognized and is not complled. How do I get it into the make list?
Julien D
Julien DBest answer
Hi @fritz3917,
There is no managed build, so you must define your new source file manually, preferably by editing the top-level CMakeLists.txt file:
# Add sources to executable/library
target_sources(<PROJECT_NAME> PRIVATE
 # User defined sources
 core/src/newFile.c
 <PROJECT_NAME> to be replaced according to your project (see used value from the cmake files).
Julien D
Julien DBest answer
Hi @fritz3917,
 core/src/newFile.c
fritz3917Author
Thanks, that worked.
