Maxime MARCHETTO
ST Community Manager
Nov 19, 2026 2:00 PM UTC
What's new in STM32CubeMX2 1.2.0
Related products:STM32 software tools
STM32CubeMX2 is ST's new-generation configurator for supported STM32 devices, including the existing STM32C5 and the latest STM32G5 series and STM32H7P product lines. It runs alongside STM32CubeMX, which continues to support the existing STM32 series. Version 1.2.0 tackles the small things that can slow you down every day.
Search for peripherals and settings, and pick the middleware version for your project.
Find a peripheral or setting fast
You know you want SPI2, so why scroll for it? Peripheral search and filtering narrow the list based on what you type. Inside a configuration view, text search helps you find the setting you’re looking for. DMA settings are not searchable yet.
Choose a middleware version
Not every project needs the latest middleware. In version 1.2.0, you can choose from the versions available for your project before you generate any project files.
A few more things
  • EXTI lines — a used EXTI line now takes you to its configuration.
  • Module parts — you can configure individual parts of a module.
  • Build profile — select debug, release or both in the graphical interface.
  • Project loading — projects show their progress while they load, and you can cancel project creation or opening.
  • Packs — install packs from an STM32Cube embedded software package. The tool reads pack licence terms from disk.
  • Pack updates — update a pack and its dependencies together.
  • Layout — the interface has responsive-layout improvements, except for DMA.
  • Preferences — change the font size and set user preferences from the command line.
Before you update: Check the supported devices and known limitations in the release notes. Commit your project to version control before regenerating it, so you can review the changes.
Additional resources
Your feedback shapes where STM32CubeMX2 goes next. We look forward to reading your ideas and questions on our community forum!
First published on Nov 19, 2026
