Maxime MARCHETTO
ST Community Manager
Feb 18, 2026 13:00 UTC
Introducing STM32CubeAI Studio
Related products:STM32 software tools
STM32Cube AI Studio is now available as ST’s new standalone environment for optimizing, validating, and deploying AI models on STM32 MCUs.
Evolving from the X-CUBE-AI legacy, it brings a unified workflow, improved performance evaluation, and a modern user experience designed for both embedded engineers and AI developers.
What’s new for developers
A stronger foundation for embedded AI
  • Built on the trusted X-CUBE-AI legacy to ensure consistent, reliable embedded AI performance
  • Based on ST Edge AI Core technology for aligned performance across the STM32 AI toolchain
  • Separates embedded and AI tasks to reduce project complexity
  • Modern, intuitive UI for smoother, faster development
New capabilities for embedded model optimization, validation & acceleration
  • Detailed model performance reports, including latency and memory usage
  • Experiment comparison tools to understand design trade‑offs
  • Accuracy validation on both host and STM32 target devices
  • Layer-level inference metrics visualization for deeper optimization
  • Optimized model compilation for STM32 devices with the Neural‑ART Accelerator
Smooth integration within the STM32Cube ecosystem
  • Fully compatible with STM32Cube tools
  • Reuses existing STM32 projects to simplify upgrades and transitions
  • Generates code and templates compliant with STM32 development guidelines
  • Provides secure unified authentication and API access for seamless integration with other STM32Cube tools
Additional resources
First published on Feb 18, 2026
Julian E.
Feb 25, 2026 16:01 UTC
@L_Ricardo ,
The STM32N6 DK is indeed supported.
The list of board you see is linked to STM32CubeMX. Please try to update it.
If you still cannot find a way to select the N6, please create a thread in the edge ai community (if you don't have already).
Regarding the deployement of yolov8 and v11, I already share this point with the model zoo team. They are working on a delivering a new tutorial step by step.
Ultralytics is updating their repository a lot, and it seems that the previous tutorial does not works with all versions.
To address that I asked a new tutorial, with the exact requirements in terms of versions of ultralytics, onnx etc
Hopefully, we will have it soon.
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Julian E.
Feb 25, 2026 16:05 UTC
@UHjor.1 ,
A Linux version is planned and on its way.
It was delayed because of an issue accessing middlewares in relation with the ST Edge AI Core 3.0.
With the release of the 4.0 next week, I expect to see the Linux version coming relatively soon.
In any case, a Linux version will exist for sure.
Have a good day,
Julian
Julian E.
Feb 25, 2026 16:51 UTC
Hi @Steven-LIN,
Unfortunately, no, the MPU will not be supported in STM32CubeAI Studio.
Have a good day,
Julian
Feb 26, 2026 05:21 UTC
The files that are generated by AI studio has mx configuration also. Can we change  that according to us? As when I tried to change that it corrupted the path and middlewares as it regenrated the code. What is the solution for that?
Graduate
May 5, 2026 09:44 UTC
Hi everyone,
The macOS version is said to be on its way, would there be an estimated release date?
