Faster development and design success with STM32Cube for Agentic AI
AI agents can help speed up embedded development. But getting useful results depends on giving them the right technical context and reliable tools.
STM32Cube for Agentic AI brings STM32 knowledge, validated reference code, and deterministic tools into your AI-assisted development workflow.
The goal is simple: help you develop faster and with greater confidence, while keeping you in control of your code.
Set up the workflow that works for you
Install only the STM32 context you need.
Use STM32CubeIDE skills, integrate with another IDE, or choose the tools that fit your existing development environment.
Give your AI agent trusted STM32 context
Use STM32Cube to enrich your AI agent with STM32 reference documentation and application notes, provided in a structured database and machine-readable formats.
Your agent can also access the STM32 Sidekick assistant MCP server for accurate, regularly updated support information and resources.
Start from validated STM32 code
Give your agent access to STM32 reference code and use STM32CubeMX for deterministic code generation.
This helps improve code accuracy, reduce hallucinations, and lower token usage. You stay in control and can take over development or debugging whenever needed.
Build and debug with hardware in mind
STM32Cube for Agentic AI also supports build, debug, code review, and programming workflows.
The industry-first Errata Hunter MCP server lets your agent check code against MCU errata and suggest available workarounds. Flashing capabilities help you move from generated code to testing on hardware faster.
What difference can STM32 context make?
In an ST evaluation, AI agents were asked to develop code for STM32 MCUs.
Agents using the STM32 context and guidelines provided by STM32Cube for Agentic AI generated functional code in cases where unassisted agents failed, while using 80% fewer tokens.
“STM32Cube for Agentic AI gives us more confidence in adopting AI agents in our development. It provides validated configurations, reference examples, and code review capabilities, along with deployment flexibility and the ability to regain control within a familiar development workflow.” Serge Robin, lead architect at Somfy.
Ready to try it?
Try the STM32Cube for Agentic AI beta and share your feedback with us.
First published on Nov 16, 2026
