Pierre Guiglion
A new home for ST Edge AI documentation
Related products:STM32 software tools
  • September 4, 2026
  • 0 replies
  • 480 views
If you’re building AI-powered applications on STM32, you can now access all the ST Edge AI documentation you need from one place: ST Edge AI Documentation.
The new documentation hub brings together reference material, how-to guides, and tutorials that were previously spread across separate tool pages and older wiki articles.
Instead of jumping between sources, you can start from one entry point.
Key benefits:
  • Find answers faster: search across ST Edge AI tools from one place instead of checking multiple pages.
  • Follow complete workflows: use new tutorials that walk you through end-to-end development steps that were not previously documented in one flow.
  • Work with the right version: access documentation that stays aligned with the tool releases it supports.
  • Use AI assistants more reliably: the Copy for LLM option lets you provide the actual documentation pages to an AI assistant, helping it answer from the source rather than guessing.
  • Keep your focus on development: the hub is dedicated to online documentation and complements the product information already available on st.com.
Whether you are getting started or looking for a specific workflow, the new hub is designed to reduce friction and help you move from documentation to implementation faster.
Explore the new ST Edge AI documentation hub: ST Edge AI Documentation.
First published on Sep 04, 2026
