msche.1
Feb 3, 2022 21:38 UTC
undefined reference to `HAL_ADC_Init'
I've been trying for hours to read an analog value from a pin and write it over UART with no success on my STM32MP1. I've assigned PF14 to ADC2_INN2 and set IN2 to "IN2 Differential", then I generate the code and when I try to build I get a bunch of errors with regards to HAL functions.
I have "#define HAL_ADC_MODULE_ENABLED" in my stm32mp1xx_hal_conf.h, which I thought would be what I needed.
Sara BEN HADJ YAHYA
Feb 7, 2022 08:47 UTC
Hello @msche.1​ ,
I generated a project using your ioc file and I didn't face any issue. There were no compilation error. I also tried to start a project from scratch with the same config and still, no error generated.
Could you please share your project to help you solve the issue?
Thanks,
Sara.
Sara BEN HADJ YAHYA
Feb 4, 2022 09:59 UTC
Hello @msche.1​ ,
Thanks for your feedback,
Could you please share your .ioc file and specify the CubeMX version?
Thanks,
Sara.
msche.1
msche.1Author
Feb 6, 2022 20:23 UTC
Thanks for the help @Sara BEN HADJ YAHYA​.
IOC attached.
CubeMx Version: 6.4.0-RC4
Sara BEN HADJ YAHYA
Hello @msche.1​ ,
Thanks,
Sara.
msche.1
msche.1Author
Feb 7, 2022 18:56 UTC
Strange, I imported my IOC and all my code from main.c and it's working now.
TAlme.2
Mar 17, 2023 12:34 UTC
even you enable the HAL_ADC_MODULE_ENABLED into hal conf file, you should add $(DRIVER_DIR)/stm32f1xx_hal_adc.c \ in C_SOURCES into makefile to compile all adc HAL functions.
