Feb 25, 2026 3:38 PM UTC
Unable to program STM32MP257F-dk eMMC
I'm working on STM32MP257F-DK board. I use a device tree without SD card, only eMMC. I set BOOTDEVICE_LABELS = "emmc" in my machine.conf.
When I want to program I have the following error:
~/workspace/ninja/out/release-v0.0.0-16-gcd0ce3d-dirty/images/cg-stm32mp257f-dk-emmc (amo/work)$ STM32_Programmer_CLI -c port=usb1 -w flashlayout_cg-image-core/optee/FlashLayout_emmc_stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee.tsv
 STM32CubeProgrammer v2.21.0
USB speed : High Speed (480MBit/s)
Manuf. ID : STMicroelectronics
Product ID : DFU in HS Mode @Device ID /0x505, @Revision ID /0x2000
SN : 004500464236501300333258
DFU protocol: 1.1
Board : --
Device ID : 0x505
Device name : STM32MP23xx/25xx
Device type : MPU
Revision ID : --
Device CPU : Cortex-A35
Start Embedded Flashing service
Opening and parsing file: tf-a-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-programmer-usb.stm32
Memory Programming ...
 File : tf-a-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-programmer-usb.stm32
 Partition ID : 0x01
Download in Progress:
[==================================================] 100%
File download complete
Time elapsed during download operation: 00:00:02.187
RUNNING Program ...
 PartID: :0x01
Reconnecting the device ...
Product ID : DFU @Device ID /0x505, @Revision ID /0x0011, @Name /STM32MP257FAK Rev.Y,
DFU protocol: 1.1
Board : --
Device ID : 0x505
Device name : STM32MP257FAK Rev.Y
Device type : MPU
Start operation done successfully at partition 0x01
Opening and parsing file: fip-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-ddr-optee-programmer-usb.bin
 File : fip-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-ddr-optee-programmer-usb.bin
 Partition ID : 0x02
Time elapsed during download operation: 00:00:00.201
RUNNING Program ...
 PartID: :0x02
DFU protocol: 1.1
Board : --
Device ID : 0x505
Device type : MPU
Start operation done successfully at partition 0x02
Opening and parsing file: fip-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-programmer-usb.bin
 File : fip-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-programmer-usb.bin
 Partition ID : 0x03
Time elapsed during download operation: 00:00:08.648
RUNNING Program ...
 PartID: :0x03
Product ID : USB download gadget@Device ID /0x505, @Revision ID /0x0011, @Name /STM32MP257FAK Rev.Y,
DFU protocol: 1.1
Board : --
Device ID : 0x505
Device type : MPU
Start operation done successfully at partition 0x03
Flashlayout Programming ...
Running Flashlayout Partition ...
DFU protocol: 1.1
Board : --
Device ID : 0x505
Device type : MPU
Flashlayout partition started successfully
Error: Message from Embedded Flash Loader : mmc device 1 not found
Received PhaseID == 0xFF, system is going to reboot
My .tsv file is:
#Opt	Id	Name	Type	IP	Offset	Binary
-	0x01	fsbl-boot	Binary	none	0x0	arm-trusted-firmware/tf-a-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-programmer-usb.stm32
-	0x02	fip-ddr	FIP	none	0x0	fip/fip-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-ddr-optee-programmer-usb.bin
-	0x03	fip-boot	FIP	none	0x0	fip/fip-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-programmer-usb.bin
P	0x04	fsbla1	Binary	mmc1	boot1	arm-trusted-firmware/tf-a-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-emmc.stm32
P	0x05	fsbla2	Binary	mmc1	boot2	arm-trusted-firmware/tf-a-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-emmc.stm32
PD	0x06	metadata1	FWU_MDATA	mmc1	0x00080000	arm-trusted-firmware/metadata.bin
PD	0x07	metadata2	FWU_MDATA	mmc1	0x00100000	arm-trusted-firmware/metadata.bin
P	0x08	fip-a	FIP	mmc1	0x00180000	fip/fip-stm32mp257f-cg-stm32mp257f-dk-emmc-mx-optee-emmc.bin
PED	0x09	fip-b	FIP	mmc1	0x00580000	none
PED	0x0A	u-boot-env	ENV	mmc1	0x00980000	none
P	0x10	bootfs	System	mmc1	0x00A00000	cg-image-core-cg-linux-core-cg-stm32mp257f-dk-emmc.splitted-bootfs.ext4
P	0x11	vendorfs	FileSystem	mmc1	0x04A00000	cg-image-core-cg-linux-core-cg-stm32mp257f-dk-emmc.splitted-vendorfs.ext4
P	0x12	rootfs	FileSystem	mmc1	0x14400000	cg-image-core-cg-linux-core-cg-stm32mp257f-dk-emmc.splitted-rootfs.ext4
P	0x13	userfs	FileSystem	mmc1	0xD4400000	cg-image-core-cg-linux-core-cg-stm32mp257f-dk-emmc.splitted-userfs.ext4
When I use a build with sdcard and eMMC, I can program the sdcard and I can see the eMMC. I also tried on another dk board with the same result.
I don't understand why I have this error and not found solution on the web.
