zhuij.1
Jul 23, 2024 12:29 UTC
STM32MP135DK+threadX+cube compilation failure
The following compilation failure occurs when using cubeMX (6.12.0) to generate the STM32MP135DK+threadX project:
tx_initialize_low_level.S:147: undefined reference to `_stack_bottom'
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:66: Demo5_Application.elf] Error 1
Kevin HUBER
Kevin HUBERBest answer
Aug 2, 2024 12:39 UTC
Hello @zhuij.1 ,
This is a known limitation of the latest CubeMX 6.12.0 release, you can find the solution in the CubeMX release note on the wiki:
https://wiki.st.com/stm32mpu/wiki/STM32CubeMX_release_note#With_STM32CubeMP13_package
Hope it helps,
Best Regards,
Kevin
Kevin HUBER
Hello @zhuij.1 ,
Hope it helps,
Best Regards,
Kevin
