AVazquez
Sep 16, 2020 07:54 UTC
secure boot and stm32key from
Hi, All.
In the wiki, the process to program the PKH into the OTP is done with stm32key tool in u-boot. Also, PKH file must be available in a filesystem partition. All these tasks need to be done manually...
Is it possible to do this same process from sysfs?
My idea is to be able to automate this task in a script.
Olivier GALLIEN
Olivier GALLIENBest answer
Sep 23, 2020 20:07 UTC
​Hi @AVazquez​
For automation maybe you can consider to use STM32CubeProgrammer ?
See
https://wiki.st.com/stm32mpu/wiki/STM32CubeProgrammer#How_to_fuse_STM32MP15x_OTP
For PKH OTP fuse.
I guess filesystem partition can also be manage ?
Using CLI of STM32CubeProgrammer made it easy to use in some script
Hope it help
Olivier
Olivier GALLIEN
​Hi @AVazquez​
See
For PKH OTP fuse.
Hope it help
Olivier
AVazquez
AVazquezAuthor
Sep 26, 2020 12:44 UTC
Yes , I need manage filesystem partition.
You are rigth, maybe the best option is use STM32CubeProgrammer.
Thanks!!
