Sep 27, 2024 13:11 UTC
Re: STME32CubeIDE + FreeRTOS - file "freertos_mpool.h" missing
Ok, good to know it is a known issue. And no problem with it.
What can I do then in order to proceed ?
Are there other files missing ?
How can I complete the installation and make sure eveyrthing is there ?
    MDeAuthor
    Sep 28, 2024 00:03 UTC
    Just so you know, I just searched on your forum if we had not already encountered this problem of missing "freertos_mpool.h" file.
    I found this thread here.  Problems with stm32f103zet6 using stm2cubeIDE to build freertos projects
    Your colleague there suggests going back to version 1 of CMSIS.
    I don't see any problem, that's what I did.
    And now it works ! Everything compiles perfectly until the end without error or warning.
    I now move on to the next step which consists of downloading the binary code normally obtained to the "STM32F107-VCT6" chip at my disposal.
    Thank you for the speed of your answers.
    I will not hesitate to come back to you if I encounter other problems that I cannot solve.
    Kind regards,
    MDe / Belgium
