Oct 25, 2024 22:16 UTC
Installing the x86_64 SDK
Hello, I am trying to install the SDK to work on the STM32MPU257F-EV1 Development board and I followed the instructions for the x86_64 Architecture, however when I use the command echo $ARCH it says the architecture is arm64? Is that what should be displaying? I feel like it should be x86_64 right? Thanks!
Carson
gbm
gbmBest answer
Oct 26, 2024 05:36 UTC
In order to work on projects for STM32MP, which is ARM-based, you need to install tools for ARM target. You are installing these tools on x86-64 architecture host, I assume. The tools report target architecture, so everything looks correct.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
gbm
gbmBest answer
CarsonAuthor
Oct 28, 2024 15:07 UTC
So when I am installing the SDK, I should still be installing the en.sdk-x86_64-stm32mp2-openstlinux-6.1-yocto-mickledore-mpu-v24.06.26.tar.gz because that is my host architecture, but it will still make an ARM64 SDK because that is the target architecture of the board?
Ozone
Principal
Oct 29, 2024 11:16 UTC
Yes.
The "arm" variant of of the SDK is for ARM-based host systems like e.g. the Raspberry Pi.
The target architecture is always "arm64".
