Sep 20, 2026 12:43 PM UTC
Error while building STM32MP2 Distribution Package 6.2.0
I’m trying to initially build the Distribution-Package 6.2.0 (v26.02.18) as stated in the Wiki (https://wiki.st.com/stm32mpu/wiki/STM32MPU_Distribution_Package#Initializing_the_OpenEmbedded_build_environment)
I am using a VM in Virtual Box running Ubuntu 24.04.5 LTS.
I attached the log file.
Any help is appreciated :)
Thanks in advance.
Ben
BSUSBest answer
Sep 21, 2026 5:28 PM UTC
@ozammo With the help of AI I could get past the libcap issue by adding the following line to a custom layer (libcap_2.69.bbapend)
EXTRA_OEMAKE:append = " CC='${CC}' BUILD_CC='${BUILD_CC}'"
Now the building process finished successfully.
Thank you for your help :)
Sep 21, 2026 8:31 AM UTC
Hi Ben,
I have not built this specific package before but I do live and breath Ubuntu so I will see if I can help.
Would you be able to give me some specifics on which steps you have completed and which specific command is giving you that log?
BSUSAuthor
Sep 21, 2026 8:41 AM UTC
Hi ozammo,
I did a clean install on the Ubuntu 24.04.5 LTS in VirtualBox (My host system is Windows 11). Thereafter I updated and installed all the needed packages for the Yocto-Building process.
And then I followed the mentioned commands here (https://wiki.st.com/stm32mpu/wiki/STM32MPU_Distribution_Package) just by changing to version 6.2.0 instead of 6.2.1 with the following commands:
repo init -u https://github.com/STMicroelectronics/oe-manifest.git -b refs/tags/openstlinux-6.6-yocto-scarthgap-mpu-v26.02.18
repo sync
DISTRO=openstlinux-weston MACHINE=stm32mp2 source layers/meta-st/scripts/envsetup.sh
The error occurs at around task 2780 when running: bitbake st-image-weston
I did not change any files in the downloaded repo.
If you need any other information, please contact me.
Thank you so far :)
Ben
Sep 21, 2026 8:47 AM UTC
Hi Ben,
Can you tell me if this runs sucessfully
bitbake -c cleansstate linux-libc-headers
Could you also confirm if your build paths and all relevant files are truly native to your sandbox? Windows does not like sharing files for operations such as this.
BSUSAuthor
Sep 21, 2026 9:38 AM UTC
Hi ozammo,
The command runs successfully. When I restart the building process afterwards I run into the same issue.
All files are on the virtual disk (vdi).
Sep 21, 2026 9:54 AM UTC
With that information I checked for compatibiIity, it appears there is some documented conflicts between the newer host tools and the older pseduo version shipped with OpenSTLinux 5.0.8. Could you please run the command below?
tar --version
If this returns 1.35 or greater than I believe you may need to downgrade to tar 1.34 to get this to work. Your log shows some commands that are native to 1.35 and the responses are consistent with the differences between 1.34 and 1.35. They handle files differently.
BSUSAuthor
Sep 21, 2026 10:18 AM UTC
Alright I actually got tar version 1.35. I will try the build after downgrading to 1.34.
