Jul 8, 2026 1:14 PM UTC
Error on SDK build for stm32mp21-disco for scarthgap (and possibly others)
https://github.com/STMicroelectronics/meta-st-stm32mp/blob/scarthgap/recipes-bsp/trusted-firmware-m/tf-m-stm32mp.inc#L263 and the following cp commands preserve the ownership of the file which is a problem for yocto.
When I build the sdk, I am getting the following error:
Exception: Exception: KeyError: 'getpwuid(): uid not found: <my-uid-here>'
Path <path-to-build-folder>/tmp/work/x86_64-nativesdk-<distro-sdk-name>-linux/nativesdk-tf-m-stm32mp-scripts/v2.1.4-stm32mp-r2.1/sstate-build-package/package/usr/local/oe-sdk-hardcoded-buildpath/sysroots/x86_64-<distro-sdk-name>-linux/usr/share/tf-m/scripts/wrapper/imgtool/__init__.py is owned by uid <my-uid-here>, gid <my-gid-here>, which doesn't match any user/group on target. This may be due to host contamination.
The fix is quite easy, any instance of “cp -a” needs to be replaced by “cp -a --no-preserve=ownership”. So you copy every other attribute but the ownership.
I fixed it in a .bbappend but that would be nice to fix it in the source code directly: https://github.com/STMicroelectronics/meta-st-stm32mp/blob/scarthgap/recipes-bsp/trusted-firmware-m/tf-m-stm32mp.inc#L263
Bernard PUEL
Bernard PUELBest answer
Jul 21, 2026 6:50 AM UTC
Final Solution is what you proposed and it will be integrated in next releases (first on v7.0.0).
Thanks a lot for your contribution !!
Erwan SZYMANSKI
Jul 13, 2026 11:58 AM UTC
Hello ​@mathieu.jadin ,
Could you please precise which OpenSTLinux version you build, as well as your host machine OS setup (Ubuntu version ?).
Kind regards,
Erwan.
Bernard PUEL
Jul 16, 2026 9:36 AM UTC
Bernard PUEL
Jul 17, 2026 10:05 AM UTC
I could not reproduce on my side the issue but your proposal makes sens anyway (whatever the root cause is) and we may also propose another better (more generic) solution. Our integration team is looking at it ... stay tuned.
Bernard PUEL
