SS.33
Dec 5, 2022 06:43 UTC
Change the IOC UI fonts
0693W00000WKBxMQAX.pngI want to change the pin configuration fonts, I tried with colors and fonts tabs but nothing worked
Sara BEN HADJ YAHYA
Dec 8, 2022 10:40 UTC
Hello @Community member​ ,
Welcome to the community and thanks for your feedback,
You can change the Pinout colors in Pinout View Colors tab, it can be found under Pinout -> Pinout View Colors.
I hope this helps !
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
