Accessing of RCC_XBARxCFGR register in STM32Mp257F-Dk Board
Dear Sir/Mam
We are encountering an issue with writing values into channels 0–7 of the RCC_XBARxCFGR register at the address offset 0x1018 + 0x4 * x (where x = 0 to 63).We have also observed that Writing to other channels (x = 8 to 63) works as expected and Attempts to write into RCC_XBARxCFGR(0 to 7) result in the debug control exiting and generating an error.
Thanks & Regards
Akshitha Pattem
Zakaria1
Hello @Aks,
Can you provide more details about exactly what you are trying to write to these registers?
BRs,
Zakaria
PatrickF
hi @Aks ,
did you follow sequence as written in RM0457 "Flexclkgen programming flow" ?
Otherwise, you are likely stopping of fooling some of critical bus clocks.
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
AksAuthor
Dear @PatrickF
@Zakaria1
We are following the flow mentioned in the Flexclkgen programming flow.But we could not use PLL4 FOUTPOSTDIV as input for channels 0–7 of the RCC_XBARxCFGR register.
Thanks & Regards
Akshitha Pattem
