SigmaPrime
Nov 3, 2020 17:01 UTC
Wlan0: Unsupported driver ‘nl80211’
I am working with Buildroot, to flash an image on my STM32MP157C-DK2 I wanted to have Wi-Fi working it but I got this error:
Code:
Copy to clipboard
Successfully initialized wpa_supplicant
nl80211: 'nl80211' generic netlink not found
Failed to initialize driver 'nl80211'
wlan0: Unsupported driver 'nl80211'
FAIL
I configure the interfaces and wpa_supplicant.conf files correctly normally. I don’t know wthat that means but my configuration in the menuconfig and linux-menuconfig is right (I think). Does it maybe have something to do with my target machine (the STM in this case) ?
Every Kind of Help is appreciated since I am a newby in Embedded Linux
p.s I don’t know why but it seems like the Wifi Bluetooth Card is Murata-LBEE5KL1DX-883. Maybe my Kernel configuration does not support it
I linked both Kernel and System Configuration
Olivier GALLIEN
Nov 6, 2020 08:36 UTC
Hi @SigmaPrime​ ,
I guess @Lukas Brückner​ gives you useful hint about the same problem in your other post :
https://community.st.com/s/question/0D53W00000M9LPsSAN/mpu-nteraction-with-a-endpointrest-through-wifi
Do you confirm ?
Thx
Olivier
