MPoll.961
What is best way to terminate unused I/O lines, there is a lot of options on this tie high/low, set as outputs, I worked on a very low power project and we set them all to Tri-State.
Olivier GALLIEN
Olivier GALLIENBest answer
Hi @MPoll.961​
Application Note AN4899 "STM32 GPIO configuration for hardware settings and low-power consumption" might contains guideline you are looking for :
https://www.st.com/content/ccc/resource/technical/document/application_note/group0/13/c0/f6/6c/29/3b/47/b3/DM00315319/files/DM00315319.pdf/jcr:content/translations/en.DM00315319.pdf
Hope it help
BR,
Olivier
Olivier GALLIEN
Hi @MPoll.961​
Hope it help
BR,
Olivier
MPoll.961
MPoll.961Author
​Hey Thanks Olivier, that helped,
Mike
